turbo 350 leak, front seal area - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2004, 07:13 AM
Hi everyone! I have a 1972 Chevelle 360inch, 177ci weiand blower, allum, heads.... My problem is with my tranny, turbo 350 I installed new seals front and rear and it is still leaking as soon as I fire the motor up. I checked the torque convert, looks ok no cracks.... and help would be great, I'm tring to get my car together for my son's car show on friday. Thanks
Old 06-02-2004, 08:09 AM
Last journal entry: PICTURE TEST
SEAL
What happens sometimes is the spring that is on the back of the seal will pop out when you are installing it. I pack grease around that spring to prevent this from happening. I assume there are no groves in the converter. Also if the front pump bushing is bad it will do the same thing.
Keith
Old 06-02-2004, 01:08 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
Did you check the position of the converter bushing in the pump?
If the bushing has walked forward into the seal it will leak quite a bit of fluid.
The edge of the bushing should be flush with the pump body
Old 06-03-2004, 06:20 AM
thanks
thanks for the help guys I'm going to pull the tranny out tonight.
Old 06-03-2004, 03:29 PM
Jmark's Avatar
Its also possible that the 0-ring on the front pump is leaking too.
Old 06-03-2004, 06:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
======= since he posted that the leak starts when the engine is fired up , this indicates a pressure leak. The O-ring around the pump would drip continuously.
He could have a cooler line leaking .... mayb?
