Turbo 350 linkage adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2001, 07:30 AM
Post Turbo 350 linkage adjustment
I have a 23 T bucket with a 307 SB Chevrolet and a Turbo 350. I have no downshift at part or wide open throttle. Has Carter AFB (Edelbrock/Weber) Carb. What is the proper way to adjust the trans kick-down linkage at the carb? Trans and engine from 72 Nova. Thanks..dpj450
Old 10-24-2001, 06:35 PM
Post
As I understand it the kick-down cable should be hooked up to the carb so that it comes on at full throttle. Once the cable is locked into the square clip on the bracket, pull on the cable so that it's all the way out as the carb opens up full. Make sure the cable is actually hooked up at the tranny and that you seal the cable at the trans with RTV. I didn't seal my trtans and it bled red all over the parking lot.
