Turbo 350 not 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2005, 05:51 PM
New Member
Turbo 350 not 400
How do I know for sure that the Transmission I have is a 350 and not a 400, I can't find any numbers at all on it. The tail shift is 6 inches and the overall lenth of the tranny is roughly 28 inchs.
Old 07-10-2005, 06:28 PM
Wiki Edits: 49
Check the shape of the pan and then go here to confirm which trans you have.
Old 07-10-2005, 07:51 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
on the main tranny/rear end page there is a sticky at the top that will help you ID the tranny .
tranny information
Old 07-10-2005, 08:11 PM
BigDawgsEatFirst's Avatar
400SBC4Life
good links
or try this
http://www.technicalvideos.com/ident...smission.phtml
Old 07-11-2005, 10:44 AM
347mustang's Avatar
easy way to tell...the output shaft on a 400 is about the size of a pop can while the 350 is much smaller..and the 400 has a threaded hole in the center of the out put shaft
Old 07-11-2005, 08:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Not all t-400 output shafts have threaded holes in them. The threaded holes were on bolt - on yoke style shafts for the trannys in trucks
Old 07-11-2005, 08:25 PM
347mustang's Avatar
o..ok..but they are still much larger..
700r4 Swap to a Turbo 350 humanVr4 Transmission - Rearend 23 08-02-2004 08:48 AM
SWITCHING TO A 400 TH from a 350 TH 70SPORT Transmission - Rearend 6 06-23-2004 01:53 AM
A 350 from a 400 block and 327 crank. M&M CUSTOM Engine 10 05-30-2004 04:49 AM
Broken 400 SBC flexplate with a 350 block... realsquash Engine 5 04-20-2004 12:23 PM
turbo 350 Tissue Engine 3 04-09-2004 08:05 PM
