turbo 350 and Olds t-350 questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2006, 07:23 PM
Hello
I was wondering if the 350 trany in an 80's oldsmobile the same as a turbo 350 trany. do all 350 have the same transmision bolt set up?
email-
vegadragster@hotmail.com
thanx
Old 02-12-2006, 07:45 PM
If you mean ....do they all have the same transmission mounting space ( for the crossmember ) and bolt pattern for the transmission mount......YES.....
IF you mean the bolt pattern to the engine block.......NO...
They come in the Chevrolet pattern and in the BOP pattern.......some have both.....
Old 02-12-2006, 08:02 PM
Would the 350 tranny in an 80's oldsmobil be a turbo 350 trany?
Old 02-12-2006, 08:41 PM
Jmark's Avatar
Yes, they are called the same even though they will not interchange between Chevy and Oldsmobile.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 11:39 AM
Camaro-T/A motor mounts and Olds Questions Hot_Rod_Faith Engine 8 01-15-2004 01:01 PM
Switching from olds 350 to chevy 383... and now I've got problems matching up trannys elukas Transmission - Rearend 6 08-26-2003 12:03 PM
