turbo 350 prob??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2007, 02:49 PM
81 cutlass Flat Black
turbo 350 prob???
Hi so i just pulled my motor and trans out of my cat and before i pulled it i put it n neutral now i have it n my new car and it wont shift into any gears at all its not my shifter because i tried shifting it by hand on the side of the trans i have no idea what to do now
Old 06-04-2007, 08:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Give us a clue to the make , model of parts you are working with.
EDIT...
Check vacuum hook up
Check shifter hook up and detents.
Check the detent / passing gear cable from carb to tranny. Is it caught , stuck , melted??
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
350 or 383 for a Turbo application? Siggy_Freud Engine 15 07-23-2006 11:51 PM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 01:40 AM
Turbo 350 in a 66 ChevyII sledge57 Transmission - Rearend 1 10-06-2003 05:54 AM
turbo 350?? +nub+ Engine 5 10-05-2003 10:22 PM
