Turbo 350 shift shaft seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2006, 02:15 PM
Blackdog's Avatar
What is the best way to replace this seal? I dropped the pan but I don't know how to get the shaft out so I can replace the seal. Pulling the seal with the shaft in does not look like an option. Any Ideas?
Old 01-03-2006, 06:53 PM
Pop the flat type c-clip that straddles the shift arm and there is a nut on the end of shift arm inside the trans that needs to be removed , also take the long detent roller spring off that is held on with one valve body bolt. Then just pull the arm out , once you get it out you may have to file the inside end , so it will reinstall easily.
Just watch how you take the parts off so you can put them back the way they came off.
Been a few days since I was into one , but that ought to be close.
Old 01-03-2006, 10:51 PM
Blackdog's Avatar
Got it! Thanks
Old 01-03-2006, 11:14 PM
You guys are doing it the hard way......this little tool will remove the seal will taking the pan off.....just remove the shift arm and take the black tool and screw it down into the seal. Then turn the bolt and it pulls the seal. Lube the new seal and shaft and then install new seal. Use the silver tool as a seal installation tool.......
Took longer to type how to do it than to actually do it.
About $10 for the tool.....
Old 01-04-2006, 07:39 AM
Last journal entry: PICTURE TEST
seal
Yea what deuce said,,, unless you cannot get the tool in because of the floor board..... then you need to do it the hard way,,,
Keith
700r4 Swap to a Turbo 350 humanVr4 Transmission - Rearend 23 08-02-2004 08:48 AM
350 rear main seal??? Brian Morency Engine 9 06-09-2004 07:12 PM
turbo 350 wont shift joesnova2 Transmission - Rearend 22 07-18-2003 06:48 PM
Turbo 350 wide open throttle shift adjustments bigmac454 Transmission - Rearend 4 06-11-2003 11:47 PM
350 turbo in vette problem mikeweyman Engine 2 03-26-2003 08:00 PM
