Turbo 350 shifting problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2011, 06:56 AM
Hi everybody, My question is about a 1979 Trans-AM that has a Turbo 350 automatic transmission. The past month i've notice that it takes longer to shift. (it shift at a higher RPM) What would cause this problem and what should I do. I've rebuilted the transmission about 6 years ago.
Thanks
Reggie
Old 01-07-2011, 08:10 AM
SSedan64's Avatar
A vacuum leak in the hose/line to the Trans Modulator can cause that.
Info>> http://th350.netfirms.com/pages/7a2-03.jpg
Old 01-07-2011, 08:35 AM
Thanks SSedan64,
I've not been able to work on this problem yet because its been to cold. (No heat in the garage) I wiil take a look at the vacuum lines this week end.
Thanks for your reply.
Reggie
turbo 350 not shifting into 3rd waynekllm Transmission - Rearend 1 07-01-2010 08:01 PM
350 turbo shifting problem millen90 Transmission - Rearend 1 07-28-2008 09:55 PM
Turbo 350 not shifting right Gearjammers Transmission - Rearend 5 10-24-2007 05:36 AM
350 turbo shifting stanjr41 Transmission - Rearend 6 05-08-2006 06:41 PM
turbo 350 not shifting bamacj Transmission - Rearend 3 04-12-2006 08:02 PM
