Turbo 350 slipping at WOT. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2007, 08:35 PM
Hello all. I have a 79 camaro with a tranny problem. The car drives fine when cruizing, but when I go all out, first to second is nice and tight "chirps the tires", second to drive is embarrasing, very slushy, slips bad! The trans fluid is full to the mark, it's clean, not burnt, and no foaming. What could cause this, and would a shift kit and type F help? Thanks guys.
Old 05-27-2007, 11:43 PM
jakeshoe's Avatar
The direct clutches are likely on their way out. A rebuild will evnetually be necessary. You MIGHT buy some time with a valve body kit but it would be a temporary fix at best.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
350 or 383 for a Turbo application? Siggy_Freud Engine 15 07-23-2006 10:51 PM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
Turbo 350 in a 66 ChevyII sledge57 Transmission - Rearend 1 10-06-2003 04:54 AM
turbo 350?? +nub+ Engine 5 10-05-2003 09:22 PM
