A 9 tooth drive and 24 tooth driven gears will get you the 2.66 speedometer gear ratio you need according to the di-it-yourself math equation calculator on Transmissioncenter.net's website for speedometer gear parts. BUT the 24 tooth gear isn't available for the TH-350 from them, drive gears are available in 7, 8, 9, or 10 tooth, and driven gears are available in 17, 18, 19, 20, 21, & 22 tooth count gears. LINK HERE.
Their linked online calculator can be found HERE. The linked calculator says you can use a combination of a 7 tooth drive and 19 tooth driven, OR 8 tooth drive and 21 tooth driven gears. |
http://novaresource.org/speedo.htm has the formula you need and the available gear combinations for both sizes of driven gear.
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| SBC Motor and a Turbo 350..Will it work? | 31fordcoupe | Engine | 2 | 10-06-2009 10:40 AM |
| 200R4 vs 350 Turbo | knothead | Transmission - Rearend | 9 | 01-14-2008 11:19 AM |
| newer sbc 350 to older turbo 350 | yragat | Transmission - Rearend | 8 | 10-20-2007 07:52 PM |
| 350 turbo or 400 turbo? | nd500 | Transmission - Rearend | 2 | 02-21-2003 08:25 PM |
