Hotrodders Bulletin Board
#1
Turbo 350 is it too late?
Ok heres my story, put a lift on my truck and used the stock rear driveline, it came apart upon acceleration and blew apart the tranny, so after finding another tranny and putting it in about 4 or 5 times only to find out that its burnt up, I find one for sale and mount it in the truck, got a completely new rear driveline made for 200 bucks. Well after running the truck for the first time a couple days ago i noticed that something was wrong, it would slip real bad in reverse, I have to rev it pretty high for it to move in reverse and also the tranny will randomly downshift, even at 60 MPH, I can also feel some slip when in drive too, although not near as bad as reverse. Ever since I put this tranny in the truck it had a small tranny pan leak. I took it mudding and the leak got really bad so I dropped the pan last night to replace the filter and gasket to find that there is a metal chunk in the pan, I'm guessing part of a clutch, and the fluid smells burnt. I go ahead and change the gasket and put a new filter on, put fresh fluid in and some lucas tranny fix. Well nothing has changed, it still slips bad in reverse and randomly downshifts and slips in drive. On top of all that it still leaks from the pan, i'm thinking the pan is bent in one spot. But I am wondering if the tranny can still be rebuilt or is it too late or should i start looking for another tranny? And if so could you help me find a best bang-for-your-buck rebuild kit. Kind of on a tight budget since I am only 17.
Here are some pics of the truck just for fun. It may not look the best, but it sure is fun and draws attention. And I did all the work too. ![]() Last edited by donvito : 07-04-2008 at 05:11 PM. |
#2
re: Turbo 350 is it too late?
Hi donvito,
Well the trans is rebuildable, & if you still have those other transmissions, you may be able to get any hard parts you may have damaged in the one being rebuilt. Do you know how to rebuild a Tranny? If not get a manual & a video, you need some tools you may not have, in your case it may pay to buy them, as I'm sure this wont be your last rebuild, you need to be completely organized, put the small parts in baggies & mark them, don't forget to clean the fluid cooling lines, the cooler in the radiator, the converter, & your external oil cooler if you have one, if not get one, you have it apart, might as well put a shift kit in it as well. A rebuild kit is about $175 & should include everything you need. Good luck, Rich |
Back to top |
Similar Threads for: "Turbo 350 is it too late?"
| 200R4 vs 350 Turbo | knothead | Transmission - Rearend | 9 | 01-14-2008 11:19 AM |
| Turbo 350 not shifting right | Gearjammers | Transmission - Rearend | 5 | 10-24-2007 05:36 AM |
| newer sbc 350 to older turbo 350 | yragat | Transmission - Rearend | 8 | 10-20-2007 07:52 PM |
| 350 or 383 for a Turbo application? | Siggy_Freud | Engine | 15 | 07-23-2006 10:51 PM |
| Turbo 350 in a 66 ChevyII | sledge57 | Transmission - Rearend | 1 | 10-06-2003 04:54 AM |
