turbo 350 tranny work with stock converter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2011, 06:15 PM
i have 2 89 k1500 that i'm putting together to make one. i have a turbo 350 tranny with a conversion kit but the torque converter is bad. can i use the stock torque converter with the turbo tranny?
Old 07-11-2011, 11:55 PM
What do you mean by conversion kit?
Old 07-12-2011, 01:41 AM
FastOrange's Avatar
im assuming the truck has a 700R4, and you stuck in a th350 and needed a kit to make the T-Case bolt up.
and your asking if the 700R4 TC will fit the TH350.
Answer is, No.
Turbo tranny w/small stall converter Mitchman Transmission - Rearend 2 11-16-2010 07:00 AM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 08:52 PM
Cam too big for stock converter? or ? FASTCHEVY Engine 10 03-09-2006 06:55 PM
what is a stock stall converter for a 350 turbo? batman09 Transmission - Rearend 6 12-05-2004 06:19 PM
Stock Converter SBC-S-15 Transmission - Rearend 1 06-06-2004 06:52 PM
