Turbo 350 Trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2007, 01:39 AM
Turbo 350 Trans
My Nova Was Originally Set Up For 1/4 Mile, Trans Has Shift Kit And The Shift Down Cable Has Been Deleted, What Effect Does This Have On Performance, Also Its Leaks Fluid From That Missing Connection, What Should I Do?
Old 03-28-2007, 05:33 AM
A car cannot be 'killed'!
I'd recommend closing off the opening in some fashion otherwise the leak over time will most likely cause a failure. Years back I had a TH350 rebuilt and the builder forgot to install the 'O' ring in that same location and over time the tranny failed.
Good luck.
Old 03-28-2007, 08:00 AM
Last journal entry: car is painted
If you are using a stock valve body, you should use the kick down cable. This increased line pressure and will help your trans to live.
Old 03-29-2007, 11:33 PM
I ran one with the kickdown cable disconnected for a few months with no problems. It would short-shift on a WOT run through the gears, and obviously would only downshift if I used the shifter, but it didn't hurt it.
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
350 Turbo Trans greywulf Transmission - Rearend 3 03-29-2005 09:17 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
Turbo 350 to a '94 700R4 or 4L60 classic_chevy_guy Transmission - Rearend 9 01-27-2004 09:32 PM
Turbo 350 Trans in '63 Chev p/u Freedo Transmission - Rearend 1 09-04-2001 07:59 AM
