turbo 350 trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2010, 02:44 AM
turbo 350 trans
Hi Guys
having trouble with a turbo 350 leaking badly out the front seal behind the torque. now wear do i start looking for the problem.
i had this transmission out 3 times changed the front seal thinking it was that at first , checked the converter for cracks and groves all is good there.
the last time i had it running it started leaking in about 2 min and pushed about 1 gallon of fluid. so i,m thinking now a relief valve but don't know transmissions that well. could anyone help.
Old 10-27-2010, 04:45 AM
tnsmith10's Avatar
when will it rain???
Originally Posted by roosterone
Hi Guys
check the pump bushing. odds are its "walked" out and is too close to the pump seal.
Old 10-28-2010, 06:34 PM
junior stocker's Avatar
OR, perhaps the pump halves are'nt perfectly aligned.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Filling a new turbo 350 bentwings Transmission - Rearend 2 09-29-2007 09:26 PM
350 Turbo Trans greywulf Transmission - Rearend 3 03-29-2005 09:17 PM
Turbo 350 to a '94 700R4 or 4L60 classic_chevy_guy Transmission - Rearend 9 01-27-2004 09:32 PM
Turbo 350 Trans in '63 Chev p/u Freedo Transmission - Rearend 1 09-04-2001 07:59 AM
