Turbo 350 Trans in '63 Chev p/u - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2001, 08:36 AM
Question Turbo 350 Trans in '63 Chev p/u
I'm swapping out the 3-speed manual trans in my '63 Chev Fleetside for an early 80's Turbo 350 Auto and need some advice. What do you do with the front crossmember, the one currently supporting the 3-speed? Does it have to come out, if so what is the best (easiest) way? Best may not be the easiest and vice-versa. Have everything else figured out, but this.
Thanks.
Old 09-04-2001, 08:59 AM
Post
The TH 350 should have no clearance problems, my guess is you have fabricated a rear trans crossmember. If you want to remove the old mounts, use an air chisel very carefully, they usually come off like butter. If they dont bother you, leave em in.
