-   -   Turbo 350 Trans Vacuum Signal? (http://www.hotrodders.com/forum/turbo-350-trans-vacuum-signal-9009.html)
54 Chevy 07-20-2002 07:01 PM
Where should a turbo 350 GM trans get its vacuum signal? From the intake manifold like the power brakes or the throttle signal from the carburator like the distributor?
I know the throttle cable is responsible for the kick down under hard acceleration but what does the vacuum signal do?
Thanks,
Jim
dklong 07-21-2002 03:30 AM
54chevy, the vac signal should be manifold vac. the vac modulator ,helps control the shift points of the trans, under different engine loads.
54 Chevy 07-22-2002 04:33 PM
Thanks for the feedback. I really appreciate it.
Jim
