Turbo 350 Transmission leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2007, 01:30 PM
I recently installed a rebuilt turbo 350 in my 71 Nova. I have about 50-75 miles on the car and all was going well till this weekend when I noticed a large puddle of trans fluid under the car.I have traced the leak to an open hole located on the rt side of the trans in the area of the trans lines. The leak is a coming from what looks to be an open hole that has a small wire coming from it and this is located above the pan and forward of the lines. When I shut the car off in about 30-40 seconds the fluid runs from this open area and down. I do not know what the open hole would be except some type of linkage that I did not use when installing. I know this doesn't give a lot to go with but I have had great luck before and hope someone can lead me in the right direction. If you know of a sight that I could see the exterior of a transmission this would help as well. Thanks for all your help.
Old 09-01-2007, 01:40 PM
biggeazy-e's Avatar
Should have a rubber seal there....
Old 09-01-2007, 01:47 PM
Crosley's Avatar
Wiki Edits: 1659
trans requires a detent cable attached at trans and then to the carb for kick down.
Some cables use an O ring like pictured.. modern cables use a rubber sleeve... install the sleeve FIRST , then slide cable end into the sleeve. Lube cable end, then slide it home. !
turbo 350 and Olds t-350 questions flatheadfever Transmission - Rearend 3 02-12-2006 08:41 PM
700r4 Swap to a Turbo 350 humanVr4 Transmission - Rearend 23 08-02-2004 07:48 AM
turbo 350 leak, front seal area 72chevelle Transmission - Rearend 5 06-03-2004 06:32 PM
Turbo 350 Transmission my59f100 Transmission - Rearend 0 07-17-2003 06:22 AM
400 turbo to 350 turbo problems mikeweyman Transmission - Rearend 2 04-02-2003 05:58 PM
