turbo 350 to turbo 700r? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2010, 09:19 PM
diamond mike's Avatar
throw me under the bus agian
so i was wondering, will a turbo 700 ( 2wd ) bolt in place of a turbo 350 ( 2wd )? would the flywheel have to go with the 700 onto the engine, or is the turbo 350s flywheel fine? will the splined shaft slip into the 700?
Old 04-26-2010, 10:56 PM
ericnova72's Avatar
More for Less Racer
It will bolt in using the same flywheel and the same driveshaft yoke. The 700 is longer, will require you to move the trans crossmember back on the frame to the same point as a TH-400 would mount, and you will have to shorten the driveshaft 3"+ as the 700 is longer here also. This is assuming you have the common short tail 350 trans, you would need a longer shaft if the 350 you have is the long tail truck version.
It is not a simple 1 to 1 bolt-in, you will have to move and modify things either way.
Old 04-27-2010, 04:57 PM
i have heard they are longer, well i just got a front driveshaft lengthened the other day for my 4x4 was about 80$, so i guess if it needs to get cut i can go there. ( it is a short tail 350 ) well, as long as i just gotta move the cross member mount, thats not too bad. ( that and the driveshaft mod ) but the flywheel that went to the 350 is fine? this is the 4th tranny ive put in this ice cream truck . first was my fault, didnt assemble with converter INSIDE tranny, so after a loud clunk as i forced it together, i find out u have to do it with converter in tranny ( destroyed front pump ) the 2nd was bad ( tried saveing $ from junkyard, ) the 3rd failed , not sure why, but found what looked like cloth pieces in fluid.....
Old 04-27-2010, 05:47 PM
fast68's Avatar
likes chevy trucks & boobies
9" tail th350 was in 2wd trucks 73 up
same length as 700r4
Old 04-28-2010, 03:09 PM
well i guess ill just have to go out and pull it ( in the f...n rain ) then once its in IC truck ill know for sure. i had considered just trading the whole truck for a GOOD turbo 350 ( has lots of dmv penalties, just my parts truck now, but does run ) so ill let yall know how it goes, mike
Old 04-28-2010, 11:34 PM
well jobs done, was done a few hrs ago, came out of the 87 chev truck and into the ic truck. and you know, they were the same size. im glad i just got out there and did it, now i still got a tbi 350 engine for whenever i need it. the linkage had to be fabricated a little to compensate for a additional gear, but runs fine.
turbo 350 and turbo 350c riley81GMC Transmission - Rearend 6 12-12-2009 09:07 PM
SBC Motor and a Turbo 350..Will it work? 31fordcoupe Engine 2 10-06-2009 11:40 AM
350 Turbo Locking up in L1 chrispc88 Transmission - Rearend 4 07-23-2009 01:33 PM
need help deciding on using 700R or turbo 350 TheCiscoKid Transmission - Rearend 7 09-07-2006 12:54 AM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 01:40 AM
