turbo 350 vaccuum line help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2003, 04:00 PM
New Member
Talking turbo 350 vaccuum line help
Where does the vaccuum line from the transmission need to connect or pull vaccuum from ? Turbo 350 on a chevy 350.
Thanks
Old 01-31-2003, 04:22 PM
Frisco's Avatar
Glad To Be Here
Post
[quote]Originally posted by solgood71blazer:
<strong>Where does the vaccuum line from the transmission need to connect or pull vaccuum from ? Turbo 350 on a chevy 350.
Thanks</strong><hr></blockquote>
It will need FULL manifold vacuum. You can connect it with a fitting to the port in the intake just behind the carb mount or you can use the FULL vacuum port at the base of the carb. Use a steel line with short hose connections at the ends to prevent the hose from collapsing.
