Turbo 350 vibration? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2009, 11:58 AM
I'm not sure I can describe this but I have a question. The trans, operates fine shifts, downshifts,no slipping. It's connected to a 250/6. In gear at an idle it feels like trying to go or like there is a higher load in the engine than there should be. You just give it a little gas car accelerates fine but in gear idling with the brake on it feels like the torque converter isn't letting the engine free wheel as it should. I don't know what the converter is rated at or out of since the trans and converter came from 2 different places. Does it sound like that would be a possibility or I may be way off. The trans has been in the truck for 3 years and it has always done it but I'm going to pull the motor and want to fix the trans. isssue if I can while it's out. Thanks, Eric
Old 01-27-2009, 06:10 PM
tnsmith10's Avatar
when will it rain???
did you check the engine and transmission mounts to see if theyre bad??? they can make for a bad vibration while in gear at a stop.
Old 01-31-2009, 04:23 AM
I would say either your convertor is locked up or it is the wrong stall. either way replacing it should cure your problem.
Old 01-31-2009, 06:10 AM
SSedan64's Avatar
Smaller 4cyl & 6cyl engines usually have converters with a higher/looser stall rating. That's why the truck wants to pull forward. The converter's probably from a V8 combo.
An old cheap way to get a high stall converter for a V8 engine with the TH350 trans was to use a converter from a 4cyl Vega.
Old 01-31-2009, 04:46 PM
tnsmith10's Avatar
lets get back to basics here before you gop tearing into this thing when it may not be necassary.
whats the year of truck the trans came out of? does it have a blue plug on the drivers side of the case?
did you check the mounts prior to install? what trans was bolted up to the inline before installing the trans out of the truck? and what kind of car did you install this in?
did you know that when installing a converter for a rebuilt trans that has an inline that it takes the same converter as a v-8?? p/n: gm 350 from transtar.
the v-6's depending, usually take the same converter as well, but have seen some come with special hi stall converters depending on the application.
now i have an inline 6 250 and its got a 700R4 in it but the same theory still applies to having a broken trans mount. ive had the same problem with mine, and every time mine gets rough at idle in gear, its had a broken trans mount...
and the stall in my 700 is higher than the stalls listed in the pics ive posted below with the exception of the h.p. converters... check all your mounts out
Name:	350 converters.JPG
ID:	36017   Click image for larger version
Name:	350 converters 1.JPG
ID:	36018   Click image for larger version
Name:	350 converters 2.JPG
ID:	36019   Click image for larger version
Name:	350 converters 3.JPG
Turbo 350 not shifting right Gearjammers Transmission - Rearend 5 10-24-2007 06:36 AM
350 or 383 for a Turbo application? Siggy_Freud Engine 15 07-23-2006 11:51 PM
350 Turbo noise fredmanky Transmission - Rearend 0 05-02-2006 08:01 AM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 01:40 AM
Turbo 350 in a 66 ChevyII sledge57 Transmission - Rearend 1 10-06-2003 05:54 AM
