Turbo 350,Wont downshift into Low gear when in Drive - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2002, 03:27 PM
Question Turbo 350,Wont downshift into Low gear when in Drive
I recently had a rebuilt Turbo 350 w/ Stage 2 shift kit installed in my 74 Camaro,it worked fine for the first month but now its acting up,whenever I come to a stop it doesnt like to downshift into first gear ,it randomly will but not very often..So I end up taking off in 2nd gear,The problem seems to occur more often after the car warms up,although it will manualy shift into first gear no problem,ive noticed since this started happening it waits longer (to long) before shifting from 2nd to 3rd gear (high rpm)..any ideas would be greatly appreciated!
Old 11-07-2002, 10:20 PM
Post
im not going to pretend that im a tranny god or anything but you asked for ideas so here it goes-i had the same problem with a borg-warner a couple years ago and just for fun i changed the fluid and the filter, after that i had no more problems. if it doesnt work for you you can do what my pa always said-"if it doesnt work take it apart and put it back together" :p
Old 11-08-2002, 06:29 AM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Sounds to me like the governor, it is located on the side of the tranny toward the rear. It has a cover that looks like a master cylinder cover (round). Inside this is the governor, take it out and make sure the weights etc. are moving freely. If they are moving freely, it still doesn't mean that the valves aren't working. The only real way to tell if it's the valves (in the gov. unit) is with a pressure test. Try cleaning it first (thouroughly), if this doesn't work a governor is cheap at a junkyard.
Old 11-08-2002, 03:58 PM
Post
as you can tell, im not good at all with trannys but it didnt look like anyoneelse had an idea, so i left y 2 cents but it seems like mech' has given you a much better game plan. sorry for the b.s. and happy rodding
Old 11-08-2002, 06:11 PM
Post
Sounds like bstmech is on the right track, Usually when a 350 won't downshift into 1st, its the vavle in the governor stuck. You can pull it out, and slam it on a bench a few times after a thourough cleaning, and squeeze the weights to see if the valve moves. If it doesn't, you can pull the pin that holds the gear on, and remove the valve, polish it, and you should be OK from there.
