Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Turbo 350C questions
Old 06-16-2012, 09:46 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by 65val
Oh, man...this is more difficult than I thought. Can we run a lockup convertor even though all the lockup guts from inside the trans have been removed?
What lock up guts have been removed? About the only item that can be left off easily is the solenoid. The aux valve body needs to be there so the separator plate is supported to avoid internal pressure leaks.
Many converter shops can build a unit that will work for you. The lock up system do not need to operate in the t-350C
