turbo 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2011, 05:20 AM
turbo 400
does anyone have a list of cars and the years that came with a turbo 400 trans that has a mechanical speedo cable
Old 12-07-2011, 09:25 PM
THE BIG AL's Avatar
SSR Engines & carburation
99% of all TH400 (if not all) came with a manual speed- o hook up.
Are you sure your looking at a TH400?
Al
Old 12-10-2011, 08:49 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The last couple production years of the t-400 were electronic speed-O setup in the USA.
As mentioned for the large part a t-400 will have a mechanical speed-O setup... if it is an electronic speed-O T-400 , that can be changed to mechanical
turbo 350 to turbo 700r? diamond mike Transmission - Rearend 5 04-28-2010 11:34 PM
turbo 350 and turbo 350c riley81GMC Transmission - Rearend 6 12-12-2009 09:07 PM
Thrush Turbo or Dynomax Super Turbo? henkelphoto Engine 3 08-25-2006 12:46 AM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 01:40 AM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 01:35 PM
