400
If the trans is a 400 for sure, and it doesn't move in forward or reverse, I would try to replace the filter and fluid first. On the THM 400 trans it is common for the o-rings on the tube from the filter to the case to get hard and leak. This lets air into the pump inlet circuit and it will not pump air! The tube goes into a heavy rubber grommet at the filter and uses an o-ring at the case, I usually put two o-rings there to increase the seal. Sometimes the filter kit will come with two but if not just find a matching one to install.
This is a cheap repair to try before you go through the effort and expense of pulling the trans and overhauling. Good luck, Rick |
oh well, the tranny is already pulled out, im only 15 and i dont have to much know-how on the situation, other then get a nice clean ply wood and take the nose peace off set it a side, next part next to the nose peace ect.
really right now i have $250 in cash and was wondering if i could get the clutch over hualed for this much or if i need to save my penneys, thanks for the repleys. Last edited by 89silverado454; 09-22-2005 at 08:12 PM. |
you have enough money, but first buy a video and watch it a couple of times. have some kind of a clue as to what you are looking at. you should be able to get a rebuild kit for under $150. step by step videos are available and easy to follow.
Go to your local trany shop and see what a carry out th400 goes for. Around here a 700r4 carry out goes for $550-750 and 400's around $350-450. If you dont no much about cars, much less tranys, then I wouldn't attempt rebuilding it yourself. You'll spend good money on parts, get it all put together just to find out it still doesn't work. Save a little more money and either buy a carry out or get someone that does tranys for a living to build it. Get a guaranty that the trans is going to work if you do it there's no guaranty. |
Yup and think of the educational oppotunities for the young fella..
Next thing ya know he will be the local tranny guy.. OMT
And he's 15, it's not like he could be driving it anytime soon, he's got plenty of time to do it. With help this website and a video he'll be fine. Some of you guys had a good point, for the trans to just drop out during the ride wouldn't be clutch related, has to be something else. |
the tranny is already out and my moms b/f is a tranny specialist and he will help me work on it, i was just wondering what this could run me up. now that im sure i will have enough money ill think of starting soon. thanks guys. heck who knows i might end up being a tranny specialist too
I just noticed your home state. If I lived up there I would be driving without my licenses too. Don't tell my dad but I put about 50 miles on my Caprice before I even had my permit or the car insured.
Good luck, keep us posted on it. |
Just a bit of an update!
This tranny seemed to be on the back burner for a while and im just getting around to it. i tore it apart about a month ago, only to find the person before me drove the living hell out of this tranny, the clutchs were gona and at least 2/3 of the rest of the tranny was JUNK! it must have been slipping for ever, looks as if there was enough friction to make it hot enough the oil tub melted and everything went cablummy from there so i picked up a parts th400, an overhaul kit, shift kit oil filter torque convertor ect. ect. and now all i need is a primary gear (which i can get for free from my mothers bf ) good to have a tranny guy around at times. today he took all the parts from the parts 400 too work to have them cleaned, and to grab the other part from work. so by this weekend i should be re-assembling my transmission. i never knew there was so little too a tranmission! only took me about 45 min my first time to take a tranny apart. by this weekend i hope to have my silverado at his house so i can put the tranny back in it and put it up for sale |
| Fan Clutch Bad After 400 miles? | Ghetto Jet | Engine | 10 | 04-02-2005 09:21 PM |
| turbo 400 or 700R trans? | Trick101k | Transmission - Rearend | 3 | 11-19-2004 12:58 PM |
| turbo 400 capability | alky496 | Transmission - Rearend | 2 | 11-15-2004 09:12 PM |
| Turbo 400 leaks into transfer case | latheman | Transmission - Rearend | 2 | 02-13-2004 06:09 PM |
| 400 turbo to 350 turbo problems | mikeweyman | Transmission - Rearend | 2 | 04-02-2003 05:58 PM |
