Turbo 400 Dead
OK here goes ,i have a M/H with a Chevy P 30 chassis 1984, i have had no previuos problems with the tranny no slipping ,no major fluid loss little drip at the back,pulled up to a stop sign and stopped went to take off nothing no reverse or forward, fluid is right full and still red does not smell burnt, what do you guys think it could be. Cherrs James |
sounds like maybe the pump isn't moving fluid. pretty easy to check. cna't remember which is pressure line I think it's the top line on the radiator. take it off put it in a jug and see if it pumps fluid. Calling all th400 guru's!!! My experience is limited here........throw this guy a bone. Brian
turbo 400
Well funny thing is when i got home and dropped in my driveway, got up the next morning started it up put the beast in gear and away it went tranny works good now, i wonder whats up with that,
maybe it was mad at you
a common thing with t-400 is the filter can clog from debris after yrs of use. The trans stops working.
As the trans sits the fluid drains out the filter and the trans will operate for a few miles then stop. I have also seen worn pumps drop off line to zero pressure like an air bubble develops inside them. Rev the engine a good whack on the throttle and pressure jumps back online.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| Turbo 400 help, Need to know what I did wrong | MAD BOWTIE | Transmission - Rearend | 8 | 12-28-2005 08:39 AM |
| Turbo 400 yoke question...? | Bumpstick | Transmission - Rearend | 8 | 12-25-2005 02:41 PM |
| turbo 400 with transfer case to 700-r4 | razzle | Transmission - Rearend | 3 | 11-04-2002 06:12 PM |
| 7ooR4 vs 400 turbo? | WBhunter | Hotrodders' Lounge | 4 | 04-25-2002 01:54 PM |
