turbo 400 failure to shift, or hold gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2002, 05:59 PM
Red face turbo 400 failure to shift, or hold gears
I'm new hear and would like to thanks you guys for this site. I have a 1985 chevy s-10 with a heavily built 350. Since i bought the truck it doesnt want to shift until approx 4500 rpm's. I have a B&M 3500 stall converter, and 4.11's in a 9 inch rear. Also if i let the gas go before shifting it drops to idle regardless os speed, then jumps back up to to speed the engine would be going for the MPH the trcks moving in first gear, then pulls again. Please help, modulator not sticking, but (sorry for being obviolious) but on the back of trans i took off the plate covering some sort of gear controled piece, looks like it has wings, well anyway only on side has a spring inside, could this be why, thanks a lot george
Old 11-25-2002, 07:28 PM
BOBCRMAN@aol.com's Avatar
Post
that winged thing is the governor, it controlls the trans shift v-s road speed someone probably removed the spring to make the trans shift at max rpm all the time, find another good used one and replace yours, they just slide in on a shaft.
Old 11-25-2002, 08:24 PM
Post
i have an extra chevelle transmission, with an almost identical part (i believe its also a 400 trans) it has both springs, can i use those?
Old 11-26-2002, 01:37 PM
Post
You can use just the springs or the whole governor only if it's a th400. The th250,350 and 700R4 all use a different governor gear but they look very similiar so be sure it's a th400.
