turbo 400 gearbox problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2006, 04:33 AM
I have a turbo 400 gearbox in my 4x4.I had a 308 v8 in it and have just converted to a injected v6 and i have replaced the oil pump and seal on the gearbox and changed the oil.I can select reverse but when i put it into D i take off in second and it wont change to third unless i give it some hell! nobody has helped me out with this problem and i know next to nothing about auto gearboxes
Old 10-11-2006, 05:03 AM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
turbo 4oo gearbox problems
Do you have vacuum hooked up to the modulator? I replaced the turbo 400 in my gremlin years ago, and the new(used) tranny wouldnt shift into 3rd gear,my helper forgot to hook up the vacuum line to the modulator.hooked it up and it shifted fine.
Old 10-11-2006, 11:48 PM
turbo 400 problems
just as a test i diconnected the vacume to see what it would do,I had reverse and first but no second and third when i reconnected the vacume it took off in first shifted to second but i still didnt get third.the second time it started in second and i still cant get first or third
Old 10-12-2006, 04:34 AM
Could be the o rings on the back of the pump pinched. That commodore v6 will have it's work cut out turning a real auto.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Turbo 400 help, Need to know what I did wrong MAD BOWTIE Transmission - Rearend 8 12-28-2005 08:39 AM
700r or turbo 400 yosimdisam Engine 5 02-13-2005 11:02 PM
turbo 400 problem JamesRS Transmission - Rearend 13 10-03-2004 04:27 PM
What problems should I look for in a 400 sbc? stonedchihuahua Engine 8 11-05-2002 02:36 PM
