Turbo 400 hard shifting
I have a 70 Impala with a turbo 400 trans. Once the car is warmed up it shifts into gear very hard. The hotter the car is like after driving for awhile when shifting to drive or reverse it really slams into gear. The idle speed is set correctly. Any suggestions would be appreciated. I'm not sure if some kind adjustment can be made or am I looking at rebuilding it . THANKS
common issue if the trans has a shift improver kit installed. IS this a recent change or a long time complaint?? Did you recently purchase the car?? Worn boost valve , bad vacuum modulator will raise main line pressures so a ruff engagement happens. GM installed reducer cup plugs in reverse servo feed bore to ease this engagement.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Use a vacuum gauge to check idle speed vacuum level at the modulator. Vacuum should be 15 inches or higher at idle for proper "garage shift" engagement. Less than that will cause high line pressure and harsh engagement.
Use a gauge!! |
Thanks for the info. As soon as I get car out this spring I will check a few things out. Again thanks
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| 700r or turbo 400 | yosimdisam | Engine | 5 | 02-13-2005 11:02 PM |
| turbo 400 problem | JamesRS | Transmission - Rearend | 13 | 10-03-2004 04:27 PM |
| convereter advise needed...turbo 400 | Dave Y. | Transmission - Rearend | 4 | 02-12-2003 03:00 AM |
| turbo 400 with transfer case to 700-r4 | razzle | Transmission - Rearend | 3 | 11-04-2002 06:12 PM |
