Turbo 400 Leaking from vent - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2006, 12:56 PM
Hello all. I am not very well versed in the field of automatic trannies. My 1979 GMC 3500 454 t-400 will leak from the little tube at the top of the tranny when the truck is running and parked on a down slope. Level ground or upslope no leaking. Not running no leaking. When running the leak gets progressively worse with time. The tranny is a reman and doesn't have but mabey 5000k and 1000k of towing. Is this tube an overpressure relief? Why would it do this? Please use technical and layman terms to help.
Yhank you very much.
Old 03-18-2006, 04:39 PM
That is a vent tube , nothing should come out of it, you may have a servo seal leaking slightly and aerating the fluid and making the level too high.
But first of all check the fluid with truck level and dead cold and make sure it is not overfilled.
Old 03-18-2006, 05:15 PM
The fluid level is correct. What kind of cost am I looking at to replace the servo seal? I am smart enough to have installed the tranny but that was plug and play, not trouble shoot and fix. thanx again
Old 03-18-2006, 06:58 PM
If it is a servo seal , that means it has to be totally rebuilt, because there is more than one seal in the trans, each clutch pack has them. So to totally eliminate the problem its a total rebuild.
Old 03-18-2006, 08:40 PM
Thanks for the info
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Turbo 400 help, Need to know what I did wrong MAD BOWTIE Transmission - Rearend 8 12-28-2005 09:39 AM
turbo 400 with deep pan orangecrush Transmission - Rearend 8 12-15-2005 04:46 PM
700r or turbo 400 yosimdisam Engine 5 02-14-2005 12:02 AM
turbo 400 transmission 63 vette Transmission - Rearend 4 01-03-2003 03:13 PM
