Turbo 400. Leaks/Drive Shaft Play. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2008, 04:08 PM
At the back of my transmission it leaks where the drive shaft goes into the tranny & the drive shaft has a little play. Is it normal for there to be some small play where the drive shaft goes into the tranny? What do I need to do to fix it? I know nothing about transmissions. Any responses are apreciated.-Thanks
Old 10-01-2008, 04:31 PM
prostreet6t9's Avatar
Differential/Driveline
sounds like a bad bushing,when you pull the D/L out make sure and check the slip yoke for wear also.Easy fix,If you dont have a bushing driver,just remove the extension housing and run it down to the tranny shop and have them put a bushing and seal in it,get a new gasket and bolt back together.
Old 10-01-2008, 04:43 PM
PutPut72's Avatar
Earplugs are in the glovebox
Prostreet6t9 is right on the mark. Only thing I have to add, is if your yoke checks out OK but has a groove worn into it where the seal rides, check out something called a Speedie-Sleeve. Its a stainless sleeve that goes over the worn part of the yoke. If the groove is real bad you can use some special Metal epoxy and fill the groove, sand it when it dries, and put the sleeve on. I have used them alot and love em. They save some dough and the fix is permanent. Just my thoughts...
How much Tail Shaft Play??? Not A T 25 Transmission - Rearend 9 06-22-2006 08:01 PM
400 turbo short shaft transmission mattdimke Hotrodding Basics 1 07-26-2005 11:26 PM
Tubro 400 tailshaft &drive shaft Problem MAD BOWTIE Transmission - Rearend 11 06-19-2005 11:51 PM
700r or turbo 400 yosimdisam Engine 5 02-13-2005 11:02 PM
HEI shaft play adryan16 Engine 6 03-21-2004 07:58 PM
