Turbo 400 manual valve body - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2006, 07:12 PM
Tbucit's Avatar
Last journal entry: Kinda showing off
I am looking at this part on Ebay. Here is the description and part number is a B&M valve body P/N 20214. Is this a good one for the street? The description is as follows:
This valve body will give firm positive shifts and full manual operation necessary for maximum performance. The forward gear shift pattern has been reversed so you are up-shifting away from neutral. This valve body also gives full deceleration in second and first and has B&M's low-band apply safety feature. The valve body can be used on all TH-400's made from 1965 through 1994.
Not sure if the owner knows if this is a forward or reverse valve body. I have tried to call B&M but can't get anyone on the phone. Any help?
Thanks
Randall
Old 07-26-2006, 05:58 PM
The Maintenance Geek
It's a reverse Valve body, PRN12D
Old 07-26-2006, 08:38 PM
Tbucit's Avatar
So it's not what I need for the street right? I understand that a reverse shift does not have any decel when you downshift.
Thanks
Randall
Turbo 400 with manual valve body & reverse pattern... Bumpstick Transmission - Rearend 5 12-26-2005 03:51 PM
Turbo 400 yoke question...? Bumpstick Transmission - Rearend 8 12-25-2005 02:41 PM
turbo 400 with deep pan orangecrush Transmission - Rearend 8 12-15-2005 03:46 PM
AOD Valve Body ?s mustang66maniac Transmission - Rearend 3 03-15-2003 02:12 PM
manual valve body question cuda66 Transmission - Rearend 2 02-10-2003 05:11 AM
