Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Turbo 400 - No reverse/No 3rd
Old 06-19-2012, 02:18 PM
Rattmoses Rattmoses is offline
Rattmoses
Turbo 400 suddenly does not move in reverse and after pushing it out of the garage for a road test, I discovered it does not shift to 3rd. The transmission was working great until I had accidently started it in reverse one day ( no neutral switch. I have since checked fluid,adjusted linkage,replaced modulator and vacuum line. Yes, I will be installing a neutral switch in the future. Can someone explain to this amatuer what the center case to case bolt is ? As I understand it, it may be lose. Can the rear servo pin length suddenly be out of adjustment? it does seem to me that reverse is holding some pressure , but not enough.
