You need to check under it on the trans where it hooks to the modulator it could have came off when you where changing things around. I have done it myself a time or two. If it was working before the swap it can't be much .JMO. Cole
Im still learning and was told vacuum from manifold was correct way ? however the vacuum is stronger on 650 carb which one is correct ? I have a 454 in a 61 chevy with turbo 400 out of a 1988.
have you verified good vacuum at the modulator?
Is it possible the shifter was knocked out of adjustment?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| 350 turbo to 400 turbo swap in lemans?? | mtmniles | Transmission - Rearend | 8 | 01-24-2006 12:40 AM |
| Turbo 400 help, Need to know what I did wrong | MAD BOWTIE | Transmission - Rearend | 8 | 12-28-2005 08:39 AM |
| 400 turbo to 350 turbo problems | mikeweyman | Transmission - Rearend | 2 | 04-02-2003 05:58 PM |
| turbo 400 with transfer case to 700-r4 | razzle | Transmission - Rearend | 3 | 11-04-2002 06:12 PM |
