Turbo 400 not shifting soon enough - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2002, 06:16 PM
Unhappy Turbo 400 not shifting soon enough
Hi all,
I have a 462 big block chevy, big cam stock exhaust with a turbo 400 in a 1959 Cadillac.
The tranny doesn't seem to shift soon enough.
I backed the adjustment screw almost all the way out on the vacuum modulator and this helped a little but it still doesn't seem to shift soon enough.
Any ideas?
Mike
Old 10-09-2002, 06:18 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Check your governor to make sure it isn't sticking.
Old 10-09-2002, 07:43 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
We had that problem withe the 400 in my friend's '41 Willys pickup and played with the governor springs to fix it. As I recall, the shift kit we got has a set of different springs so we could tune it just like an ignition distributor mechanical advance. Call TCI, B&M or one of those outfits and I'll bet they set you up with what you need before you can say "boy howdy!"
