turbo 400 not working - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2005, 01:59 PM
Put a rebuilt 350 with a turbo400 in my 49 chevy pickup last fall. I rewired the entire truck and just turned it over today. It started up on the 1st crank.
I was so happy and proud because I never put a engine or wired anything in my life. Now for the bummer. The turbo 400 was in there with my 327 and it worked when I pulled it. I just put a lokar shifter it it Monday. When I put it in nothing. Now this might sound like a stupid question but mind you I never messed with a tranny before so bare with me. Should the torqe converter turn with the fly wheel even when the tranny is in park.
Old 03-05-2005, 02:56 PM
If the engine is turning........so should the torque converter.
They are bolted together...........isn't yours?
MIGHT be the problem.........
Old 03-05-2005, 03:10 PM
Right after I posted this I got a stupid feeling. Your right the torque coverter
was not bolted up. I must of had a brain freeze. Anyhow It works fine after I put the bolts in the converter. Like I said this is all new to me and I am happy that it all is working so far. I would like to thank all the hep that I have recieved from this site. There is a lot of info that members had given me. I turn 50 in 13 days and It shows your never to old to start to learn if you want. Best of all it's been a good experence for myself and my 23 year old who has been helping
Mark
Old 03-05-2005, 08:12 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
At least it was something simple and cheap to fix (NO cost is the best form of cheap).
Old 03-05-2005, 08:18 PM
OddRodder's Avatar
CORNFED and INBRED !?!
Mark
Man!! That sounds dumb enough to be something that I would do!! Just KIDDIN' Mark!! Hey, the pickup DID start on the 1st crank, so you had to do alot of things right!!
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 01:40 AM
turbo 400 with deep pan orangecrush Transmission - Rearend 8 12-15-2005 04:46 PM
350 turbo or 400 turbo? nd500 Transmission - Rearend 2 02-21-2003 09:25 PM
convereter advise needed...turbo 400 Dave Y. Transmission - Rearend 4 02-12-2003 04:00 AM
Turbo 400 Sandman Transmission - Rearend 2 05-27-2002 03:05 AM
