turbo 400 only has 5 gear positons - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2009, 08:23 PM
85 k5 mud truck's Avatar
****** bowtie
the trans has park, reverse, neutral, drive, and a nother gear, low range maybe??? i was wondering if i could put a manul valve body on it and be able to shift gears because its going on a mud truck and i need 1st , 2nd and 3rd only . and help???
Old 05-31-2009, 08:31 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Park/reverse/neutral/3/2/1/ this is the way it should be. Yes you can have a manual valve body installed. Mud truck or not people run them on the street also. Cole
Old 05-31-2009, 08:39 PM
****** bowtie
theres only one position after drive. is there something wrong with this ? Matt
Old 05-31-2009, 08:49 PM
eloc431962's Avatar
Wiki Edits: 37
What kind of shifter do you have . If its after market it might be out of adjustment. If the shifter is all good then there is definetly something wrong somewhere. Cole
Old 05-31-2009, 08:56 PM
****** bowtie
factory 85 k5 steering cloum shift, it only moves 5 on the gear slector on the the trans it self
Old 05-31-2009, 09:04 PM
eloc431962's Avatar
Wiki Edits: 37
Something is a miss here. Something not right . You could pm crosley and i know he will know what to tell you. there is definetly something not right .I know for a fact it should be park, reverse, neutral , 3, 2, 1. I mean you said its a turbo 400 and this is the pattern for it. humm now i am confused . Cole
Old 05-31-2009, 09:17 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Something is wrong with the shifter linkage of the vehicle or internal linkage on the transmission.
A quick check would be to unbolt the shifter linkage and cycle the trans linkage from park to low gear. If that is incorrect, I would pull the pan off.
I have built transmissions for land speed racing , where 'park and reverse ' was blocked out.. so there was a neutral , 3, 2, 1
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Turbo 350 Or 400 Which One Is Better CHEVY ONE Transmission - Rearend 4 11-06-2007 02:15 PM
700r or turbo 400 yosimdisam Engine 5 02-13-2005 11:02 PM
turbo 400 crossmember 68_6cyl_camaro Transmission - Rearend 3 10-26-2003 01:58 AM
350 turbo or 400 turbo? nd500 Transmission - Rearend 2 02-21-2003 08:25 PM
