turbo 400 problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2012, 08:30 PM
turbo 400 problem
I have a t-400 trans in my hotrod astrovan. the other day, it decided it didny want to come out of park when it was in reverse. it goes into drive and shifts fine, it just seems to stick in park and reverse. can anyone help me? it came on sudden so i'm hoping its a simple fix.(ya, right)
Old 06-29-2012, 12:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I don't quite get " it didn't want to come out of park when it was in reverse." Do you mean it didn't want to go into reverse from park, or park from reverse? Or?
In any event I would start by disconnecting the cable at the tranny and see if the cable and shifter work smoothly. If so, readjust the cable/linkage and see if that helps. This is on level ground, right?
Old 07-08-2012, 01:39 PM
Its wierd. Had the pan off to see if the park pin was malfunctioning. No. So i put it back together, filled it up and tested it again. Went P-R-P and it worked fine. Went P-R, fine,-D, fine, -R and no good, wheels lock up. Goes in D fine, just wont back up. Funny thing, it randomly goes into R and works fine. Im confused
Turbo 400 Transmission problem. Overheats 35chevrolet Introduce Yourself 1 07-08-2007 06:55 PM
Turbo 400 Transmission Problem 23 T Transmission - Rearend 6 02-18-2007 12:13 PM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 01:40 AM
turbo 400 problem JamesRS Transmission - Rearend 13 10-03-2004 05:27 PM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 01:35 PM
