Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - turbo 400 question
Old 01-01-2013, 08:00 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Your turbo 400 came from a truck. You need a passenger car yoke. That allows the yoke to slide in/out during operation. There are at least two different spline internal designs. One uses an O ring on the inner trans spline and a corresponding relief in the yoke with a vent hole in yoke end. The other type uses a solid plug in the end of yoke and no O ring in the trans. Mix em up and you get leak and/or spline travel issues.
