turbo 400 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2013, 08:35 PM
turbo 400 question
I'm building an old Studebaker street rod with a turbo 400 tranny and ford 9" rear end. Both have a yoke with "U" bolts for the universal joints.
I need a slip on type spline on one end or the other right ?
What is the easiest solution here?
I have a turbo 350 trans in my garage and on it the yoke slips off to expose a splined shaft but not the turbo 400
Thanks,
Dean.
Old 01-01-2013, 09:00 PM
BOBCRMAN@aol.com's Avatar
Your turbo 400 came from a truck. You need a passenger car yoke. That allows the yoke to slide in/out during operation. There are at least two different spline internal designs. One uses an O ring on the inner trans spline and a corresponding relief in the yoke with a vent hole in yoke end. The other type uses a solid plug in the end of yoke and no O ring in the trans. Mix em up and you get leak and/or spline travel issues.
400 turbo convertor question dboyett81 Transmission - Rearend 5 05-21-2011 04:56 PM
Turbo 400 question for Crosley dgcantrellsr Transmission - Rearend 2 02-28-2008 01:15 PM
Turbo 400 yoke question...? Bumpstick Transmission - Rearend 8 12-25-2005 03:41 PM
Turbo 400 Question MAD BOWTIE Transmission - Rearend 10 12-20-2005 07:49 AM
Question about Turbo 400 Requiem Transmission - Rearend 2 01-31-2002 08:52 AM
