Turbo 400 Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2005, 07:41 PM
MAD BOWTIE's Avatar
New Member
Last journal entry: At the track
Turbo 400 Question
I have a reverse manual valve body turbo 400. Today for no aparent reason when you shift from first to second the trans does not shift, it stays in first then when you shift to 3rdthe trans goes to second.The shift cable is correct and everything else works fine. I have been told it could be the second gear sprag any help Thanks.
Old 12-03-2005, 02:53 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Does the trans go to 2nd or to 3rd gear when shifted to 3rd as you posted?
IF there is no 2nd gear, the sprag may have flipped or broken. The tranny case may have blown the case lugs out that the retaining snap ring for 2nd gear fits into.
Old 12-03-2005, 05:11 PM
MAD BOWTIE's Avatar
New Member
There is no dead spot where second is suposed to be. It stays in first when you shift it into second and when you pull the shifter to the third gear postion it crisply shifts into second. I thought it was a shifter cable problem but I removed the cable from the transmision and manualy checked the detents and cable adjustment and it is perfect.The fluid is clean and not burned and the transmision operates flawesly with the exception of no high gear and it does not do anything in the second gear detent . Could it posibly be a valve body problem?
Old 12-03-2005, 05:17 PM
You have driven the car before with no problem, it just suddenly began acting up?
Old 12-03-2005, 08:49 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there is no 3rd gear?
Does reverse function correctly?
could be a valve body problem , but I doubt it. Most reverse pattern full manual valve bodys have few if any moving shift valves
Old 12-04-2005, 07:08 AM
MAD BOWTIE's Avatar
New Member
Yes, it was not under any kind of heavy load just normal driveing. Reverse is fine the transmision does not seem to slip anywhere the shift from first to second is fine, you just have to move the shifter from first to third to make it shift from first to second. The first and second gear detent in the transmission both only engage first gear. You can manualy move the transmision lever to the second gear detent start the car ans it is in first gear. If you start out in second gear detent ,which is now operateing as first and shift into third gear detent, which is now operating as second, the transmision feels like it always has there just is no way to get to high gear. This is a wierd problem.
Old 12-07-2005, 12:55 PM
Broken sprag. You will have 1 gear and high gear but no second. The sprag is just not grabbing onto the drum. Change out the sprag to a 34 element style with a pre '74 drum and you will be set to jet.
Old 12-07-2005, 03:36 PM
Siggy_Freud's Avatar
But he is saying that he has first and second gear but no third. It shifts into second gear when commanded to shift into third but doesn't ever actually make it to third gear . . . correct?
Bringing history and technology together.
Old 12-07-2005, 04:26 PM
I just looked this over and I want to make sure that we have a few things covered first. Is the car on the lift or on the ground when this is happening? If the car is in the air, it is very common that you will not see a second gear shift on a 400 or a 350. If the car is on the ground, I do not see any way that you could have 1st and 2nd but no third, with 2nd showing up where 3rd gear should be. I feel very confident in saying that the car has 1st and 3rd and no second gear.
Old 12-19-2005, 10:52 PM
MAD BOWTIE's Avatar
New Member
Yes , I think it may have just had 1st and 3rd. I took the trans apart and the sprag will turn freely both directions. and it has scuffed up the drum a little where it rides. If I replace the drum and sprag will it be allright, the other internal parts look like new.
Old 12-20-2005, 07:49 AM
Just as I suspected... the sprag is broken or "flipped". It should only turn in one direction. If you replace the sprag, everything will be just fine again. If the inner race that the sprag rides on is chattered up, you may need to replace the drum. You also need to inspect the outer race to make sure that there are no chatter marks on it. Both pieces should have perfectly smooth ground surfaces. Count how many little elements (the little grabbers) you have on the sprag. The good sprags have 34 elements, so if you need one, just let me know.
turbo 400 with deep pan orangecrush Transmission - Rearend 8 12-15-2005 04:46 PM
turbo 400 not working 49dream Transmission - Rearend 4 03-05-2005 08:18 PM
GM Turbo 400 trans front seal housing question Gary Shugart Introduce Yourself 1 01-13-2005 03:56 PM
turbo 400 crossmember 68_6cyl_camaro Transmission - Rearend 3 10-26-2003 02:58 AM
7ooR4 vs 400 turbo? WBhunter Hotrodders' Lounge 4 04-25-2002 02:54 PM
