Turbo 400 reverse pattern...? Why...? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2005, 08:33 AM
Bumpstick's Avatar
Hammer and a torch
Have a very nice built turbo 400 with fully manual valve body but also its a reverse pattern 1-2-3 instead of 3-2-1...? Why do they do this in the valve body...? Trans guru`s...?
Just curious...?
Old 05-30-2005, 05:56 PM
11secmudtrk's Avatar
mudbogger
Its set up like that so you don't have to shift it through 3rd and 2nd and also helps if your using it off road to shift from reverse to first easier.
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
turbo 400 with deep pan orangecrush Transmission - Rearend 8 12-15-2005 03:46 PM
400 turbo no reverse 68chevelleSS454 Transmission - Rearend 2 08-25-2004 11:49 PM
Reverse shift pattern brainsboy Transmission - Rearend 3 06-29-2004 02:51 PM
350 turbo or 400 turbo? nd500 Transmission - Rearend 2 02-21-2003 08:25 PM
