Turbo 400 shifting problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2007, 08:58 AM
I have a Turbo 400 on a 502 chevrolet in my 35 chevrolet. After I drive it for an hour or so, it tends to have a hard time shifting into 3rd gear. Sometimes I have to go to neutral and back to D to make it shift. I have a trans cooler on it with a fan and it is set for 190 degrees now. Level is OK and fluid looks good. I have a 2800 rpm stall converter in it.
Old 07-08-2007, 02:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
what is the history of the trans? rebuild-fresh or old or ?
What is the vacuum reading to the modulator? Full manifold vacuum?
Is reverse gear weak or pulls strong?
Old 07-08-2007, 05:26 PM
Turbo 400
Answer: New rebuilt from B&M. Probably my firsy mistake.
Answer: Supposedly rebuilt with shift kit for 600HP
Answer: Don't know but will check tomorrow.
Answer: Fuel injection system so yes.
Answer: Pulls strong
TURBO 350 shift problems chicagopd50 Transmission - Rearend 7 05-01-2006 04:04 PM
700r or turbo 400 yosimdisam Engine 5 02-13-2005 11:02 PM
turbo 350 trans not shifting out of 1st phillip24 Transmission - Rearend 3 02-25-2004 11:34 AM
turbo 400 crossmember 68_6cyl_camaro Transmission - Rearend 3 10-26-2003 01:58 AM
What problems should I look for in a 400 sbc? stonedchihuahua Engine 8 11-05-2002 02:36 PM
