-   -   Turbo 400 shifting weird (http://www.hotrodders.com/forum/turbo-400-shifting-weird-231435.html)
ryan v 04-02-2013 10:02 PM
I've got a 87 chevy 4x4 with a mild small block in it. Ever since I put this engine in my transmission has shifted weird. Would the lower vacuum pull of this motor cause this problem? It was a tbi motor but I swapped it to a carbed setup.
vinniekq2 04-03-2013 10:49 AM
describe weird?
ryan v 04-03-2013 08:05 PM
its seems like it has to rev up more than it should to shift
vinniekq2 04-03-2013 08:16 PM
check vacuum source and modulator
ryan v 04-03-2013 09:03 PM
that's what I was thinking might be the problem. do they make an adjustable modulator?
zardiw 04-04-2013 11:10 PM
Yup.............z
rick 427 04-05-2013 12:06 PM
Adjustable modulator or not,you need a min. of 17-18 in. of vacuum at the modulator in order for that trans to shift right.
ryan v 04-07-2013 11:07 PM
well I don't think my engine will pull that much vacuum. so i'm just gonna have to live with it unless I put a manual valve body in it?
