Turbo 400 shifting weird - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2013, 09:02 PM
I've got a 87 chevy 4x4 with a mild small block in it. Ever since I put this engine in my transmission has shifted weird. Would the lower vacuum pull of this motor cause this problem? It was a tbi motor but I swapped it to a carbed setup.
Old 04-03-2013, 09:49 AM
vinniekq2's Avatar
describe weird?
Old 04-03-2013, 07:05 PM
its seems like it has to rev up more than it should to shift
Old 04-03-2013, 07:16 PM
vinniekq2's Avatar
check vacuum source and modulator
Old 04-03-2013, 08:03 PM
that's what I was thinking might be the problem. do they make an adjustable modulator?
Old 04-04-2013, 10:10 PM
Yup.............z
Old 04-05-2013, 11:06 AM
rick 427's Avatar
Last journal entry: 33 WILLYS
Adjustable modulator or not,you need a min. of 17-18 in. of vacuum at the modulator in order for that trans to shift right.
Old 04-07-2013, 10:07 PM
well I don't think my engine will pull that much vacuum. so i'm just gonna have to live with it unless I put a manual valve body in it?
No down shifting on turbo 400 dub Transmission - Rearend 2 09-03-2012 12:10 AM
turbo 400 not shifting truckboy61 Transmission - Rearend 13 09-14-2009 08:00 PM
Turbo 400 hard shifting ratboy7070 Transmission - Rearend 3 03-16-2007 06:48 PM
400 turbo weird leak! bowwy Transmission - Rearend 7 02-05-2003 07:02 PM
Turbo 400 not shifting soon enough Mike Phillips Transmission - Rearend 2 10-09-2002 07:43 PM
