turbo 400 - strength - recommended upgrades? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2005, 03:42 PM
fearsomefairmont's Avatar
Howdy Folks,
Being mostly a Ford guy, I was looking for some info regarding the TH-400 in a '72 Olds Cutlass (455 big block) I just purchased.
To me, the TH-400 seems similar to a Ford C6 as a TH-350 would be a C4.
The car drives fine but seems soggy. The last time I drove it, it developed a fluid leak from the cooler lines so I parked it immediately after driving about 2 blocks.
The motor is as follows: mild ported iron heads, hydro cam w/ .475 lift and 230@.050 duration, Edel. performer intake, Edel. 800 cfm carb, long tube headers, dual exhaust. 9:1 compression. Rear-end is B.O.P. 10-bolt w/posi. I estimate around ~300 hp, but at least 450 ft/lbs torque.
Do you think 2 blocks with poor fluid pressure burnt the clutches? Any mods to be done to the tranny? I am planning on putting in a 2800 rpm stall converter and bigger cooler soon.
Should I get a different valvebody? Would an aggresive shift kit work fine or not? I would just like to put on a shift kit and leave it (CHEAP!).
Let me know your thoughts. This is a mostly street car.
Thanks,
Andy
Old 01-16-2005, 07:39 PM
Will I ever get it done?
Last journal entry: Hood
IMHO, one of the great things about a Turbo 400 is that you don't have to buy a shift kit to get decent shifts for the street or strip. Leave out 5 of the balls (all 6 if you know which hole to plug in the seperater plate and don't mind no engine braking in 1st). Turn the accumulator piston upside down (throw out the spring - you may have to purchase a "no-leg" accumulator depending on your tranny). Plug the low shift hole and grind off the side of the valve. For the strip, you have to plug a hole in the center support and leave out the middle seal on the clutch piston. A better sprag (34?) would be a good investment for the strip.
Old 01-16-2005, 09:35 PM
jakeshoe's Avatar
I would recommend against the above mods..
Personally I would install a Transgo reprogramming kit. It will dual feed the direct clutches without tearing into the trans, opens the feed holes for fimer shifts, changes the accumlator valve spring for firmer shifts, and can increase line pressure.
Flipping the accumulator piston can cause failures and some of these mods will cause brutal part throttle shifts. The TransGo kit will have a progressively harder shift with more throttle.
Old 01-16-2005, 10:02 PM
I modified the 400 in my 3800 lb 60 Chevy w/ a 396 during a complete rebuild and I modified the 400 in the 68 Suburban w/ a 454 that I used to tow it. The wagon had over 400 passes on it without any work or failures. I can't remember how many miles I put on the Suburban daily driving, towing, and bracket racing it. My wife probably thought it was a little harsh on the shifts, but it didn't bother me. And no failures. The tow vehicle cost me the price of a 1/4" bolt, an allen bolt (can't remember the size), seperater plate gaskets, pan gasket, filter, and about 4 qts. of tranny fluid.
Old 01-17-2005, 12:39 AM
jakeshoe's Avatar
I've done the same modifications before I knew better.
It does make it shift hard.
One trans didn't live past the first WOT 1-2 shift behind a mild 427.
Accumulators are designed into a trans for a reason beside just softening up shifts.
Shift timing on a 1-2 upshift, and a 3-2 downshift are critical on a TH400 and Th350.
Get it wrong, and you ruin sprags (yes even HD 34 element ones) and break parts.
The $45-50 for a TransGo kit is well worth the money IMO, as it gives some option as to shift firmness, yet retains the accumulators function, and dual feeding the somewhat weak direct clutches all at the same time.
Lots of ways to get there, lots of ways to break parts.
Most people have no way of knowing what the low exhaust is, or have extra VB gaskets, etc.
Kit is worth the price of admission for a beginner, because of thorough instructions.
Old 01-17-2005, 02:11 PM
Sounds good
Well, the consensus seems to be just to use the Transgo kit. The price is certainly reasonable.
I will upgrade the sprag to a heavy duty one when I get to putting some Edel. aluminum heads on the motor, I am sure upgrades will be needed as a good olds 455 can put out 550+ ft/lbs of torque.
From what you say, a good shift kit is acceptable. I don't want shifts that rattle my teeth out, so I am going to stay away from other mysterious valvebody mods.
I also just installed a Hurst pistol grip quarter stick on the floor. That is such a *****in' shifter - when you slam it forward its like shooting your opponent.
Thanks for your help -
Andy
