turbo 400 torqe pattern - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2006, 01:23 AM
Iím trying to rebuild a turbo 400 automatic transmission and I need to know what the torque pattern is and how much torque should I use
Old 02-19-2006, 10:21 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
on what particular parts of the t-400 or all of them?
I use 17 - 18 FOOT pounds on the pump. Tighten opposite side bolts as a pattern
100 INCH pounds on the valve body bolts. Start in the center work out in circluar patern.
Pan torque can vary due to type pof gasket used. I suggest staying away from cheap cork gaskets..
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 01:40 AM
Turbo 400 with manual valve body & reverse pattern... Bumpstick Transmission - Rearend 5 12-26-2005 04:51 PM
Turbo 400 yoke question...? Bumpstick Transmission - Rearend 8 12-25-2005 03:41 PM
Turbo 400 reverse pattern...? Why...? Bumpstick Transmission - Rearend 1 05-30-2005 06:56 PM
350 turbo or 400 turbo? nd500 Transmission - Rearend 2 02-21-2003 09:25 PM
