Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Turbo 400 trans speedometer gear?
Old 06-18-2006, 06:17 PM
Pro Street's Avatar
Pro Street Pro Street is offline
Go Pokes!
I have had the tail housing off before.So that will not be a problem.The problem,is the gear pressed on the shaft?If it is I will have to find a puller that is long enough to pull the gear.
Thanks
