Turbo 400 trans speedometer gear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2006, 11:23 AM
Pro Street's Avatar
Go Pokes!
I have a Turbo 400 trans and would like to get the speedometer right.On the main shaft there is a steel gear.I need to change it from a 18 tooth to a 15 tooth.Can I change it with the trans in the car?
Here is a good speedometer gear web site.
Trans gears
Old 06-18-2006, 11:49 AM
Yes ... you can change it ... if you can get the tailhousing off ...
Some vehicles ( custom mostly ) are built so the tailhousing is difficult to remove. Mine is NOT ...
Just remove the driveshaft, and the raise the transmission enough to get the tailhousing clear of the crossmember ( or remove the crossmember ) and remove the speedometer driven gear ... and the tailhousing should come right off ...
Old 06-18-2006, 06:17 PM
Pro Street's Avatar
Go Pokes!
I have had the tail housing off before.So that will not be a problem.The problem,is the gear pressed on the shaft?If it is I will have to find a puller that is long enough to pull the gear.
Thanks
Old 06-18-2006, 06:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the photo Deuce has posted is not indicative of a t-400 tranny.
The speed-O bullet on a t-400 is in the main case section, not the tail housing
You will need some type of a narrow puller to reach up inside the trans pull off the steel speed-O gear on the t-400 output shaft once the tail housing is off the trans.
I've built a U shaped puller with long legs in the past to pull off metal press on type of speed-O gears. Slip the U shaped around the back of the gear , then thread the puller down onto the output shaft .... the gear slides off. Some times a bit of heat from a propane torch helps the gear to pull off easier.
Old 06-18-2006, 10:02 PM
TRUE ... but I posted it to show the relationship of the two gears.
Old 06-19-2006, 06:42 AM
Pro Street's Avatar
Go Pokes!
Thanks guys!
I will see if I can come up with a puller.
Choose Pontiac 400 or 455? & Turbo Questions TheMonkey Engine 33 08-12-2009 12:01 AM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 01:40 AM
turbo 400 problem JamesRS Transmission - Rearend 13 10-03-2004 05:27 PM
TURBO 400 TRANSMISSION wiretwister Transmission - Rearend 6 10-21-2003 06:52 PM
convereter advise needed...turbo 400 Dave Y. Transmission - Rearend 4 02-12-2003 04:00 AM
