TURBO 400 TRANSMISSION - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2003, 09:56 AM
Post TURBO 400 TRANSMISSION
I HAVE A TURBO 400 WITH A VACUME MODULATER. MY PROBLEM IS I DO NOT HAVE A PASSING GEAR. I HAVE A NEW ELDERBLOCK 600 CARB AND WAS WONDERING IF I MAY NEED TO INSTALL SOME TYPE MECHANICAL LINKAGE TO GET PASSING GEAR. TRANSMISSION SHIFTS GREAT OTHERWISE. SORRY BUT I KNOW NOTHING ABOUT AUTOMATIC TRANSMISSONS
Old 02-09-2003, 10:33 AM
Seon's Avatar
Post
A passing gear just drops it from third to second gear. You can accomplish this by manually shifting.
Old 02-09-2003, 11:37 AM
Post
400 Turbos have a electric kick down. If your vechicle came with the Turbo 400, it should have a electric switch mounted on the carb linkage or the carb. I believe they are reproing them now if you cannot find a good used one.
Also....Lokar of Knoxville TN (street rod parts manufacturer) make a kit to do this. About $50-$60 if I remember correctly.
<a href="http://www.hotrodsworldwide.com/catalogs/lokar.htm" target="_blank">http://www.hotrodsworldwide.com/catalogs/lokar.htm</a>
There is a small electical plug on the drivers side near the rear of the Turbo 400...that's where the wire goes for the kickdown from the carb switch.
:p :p
Old 02-09-2003, 01:35 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
I have used stop light switches from motorcycles to hook a kick down up on a t-400. You need the type that has a pin that a spring hooks to and pulls the pin to activate the switch.
A short length of chain or something similar from the carb linkage to the switch works well.
Be sure to keep things out of the way so nothing binds or buggers up the throttle at WOT!
Old 02-09-2003, 01:45 PM
Post
i put my kick down on a toggle switch, when runing in trafic and you flip the switch the trany is waiting on you when you hammer the throtle its ready, no delay. good luck.
Old 02-24-2003, 12:08 PM
Post
Thanks guys: I used the toggle switch method suggested by Toymobile and fixed my problem.
Old 10-21-2003, 06:52 PM
ford Auto, installed Elderblock
I just installed a 600 CFM Elderblock on my 1984 F150 (302) and I can not get it to shift out of first. Any suggestions ? I hooked up the vacuum line but was not able to install the "passing gear kickdown". I was planning to downshift into pass gear manually.
Thanks
**** Disregaurd, I had to "hook" up the kickdown in order to make the trans shift.***
