turbo 400 transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2003, 11:06 AM
Post turbo 400 transmission
I have a turbo 400 transmission that is leaking oil from the overdirve pickup. What is the best way to get it out and fix. do i need special tools. tx
Old 01-02-2003, 01:26 PM
Post
Whats an overdrive pickup? Never heard of it, can you describe it and tell us where you got the description of this part.
Old 01-03-2003, 08:44 AM
Post
Sorry..........As u can tell i'm not a mechanic..... the part, i believe is to shift into passing gear. Its not connected in the car i bought but leaking pretty badly. Its a blue plastic piece with a place for an electric connection. Its located on the same side where the speedometer cable connects to the transmission. Thank you.
Old 01-03-2003, 01:33 PM
Post
Ok, I see now. You will need to drop the pan and remove the wires from the plastic piece. There are two tabs inside that need to get pressed in and then the piece can be pushed out. Hopefully the piece isn't brittle from age.
When it's out you will find an o-ring on it, you can go down to the autoparts store and get a universal o-ring, save yourself the headache and don't bother telling them what it's for (or go to a small family owned transmission shop).
Clean all parts with brake cleaner and maybe apply a small amount of silicone sealer. And reassemble it.
Old 01-03-2003, 02:13 PM
Post
Hi Jason......... thank u so much for the for the info. Can i replace the existing gasket (material)with silicone gasket goop they sell at the parts store ?? if so...do u recommend any particular brand ???? thanks again Jason
