We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 12-24-2005, 07:19 PM
Bumpstick's Avatar
Bumpstick Bumpstick is offline
Hammer and a torch
Turbo 400 yoke question...?
Did a swap from a turbo 350 to a turbo 400 along with yokes of course (was a bolt in turbo 400)... Went to 1350 yokes on both ends (12 bolt rear end also)... Had the drive shaft built after what I thought was good close measuring... This is a 69 C10 with the ladder type rear suspension and is lowered approx 2 1/2 inches from stock height so not alot of travel is left...
How much travel in the yoke do I need...? As of right now I have about 1/2" before it bottoms out... I do not carry anything but race the truck (has a BBC powering it approx 450hp)...
Recommendations...?
Old 12-24-2005, 07:47 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Recommendations...?
I would recommend at least 1/4 inch from bottomed out at its deepest point for engine mount flex.
Since you have that suspension lowered that much here's what I would do if it were mine...
I would unbolt the rear joint, push the yoke into the trans all the way and measure how far the yoke arm is from the tailshaft with the arm horizontal.
Rebolt the rear joint and then load the truck to full suspension travel.
Measure the points again and see how much is left..... I would like to see that 1/4 inch for rubber engine mount flex.
Old 12-25-2005, 11:37 AM
dgcantrellsr dgcantrellsr is offline
Put chassis (frame) on stands (4) places and let rear end drop to its lowest point and see if you still got clearance.
I have run some 4 link applictions with no more than 1/2 in.
Old 12-25-2005, 01:13 PM
Bumpstick's Avatar
Hammer and a torch
Thanks on the replies... Will be checking several ways this afternoon after the dinner wears off... (if I can get under it again...?)
Old 12-25-2005, 01:45 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Recommendations...?
Here's a link to a driveline shop's recomendations:
http://www.iedls.com/measure.html
HTH,
Don
Old 12-25-2005, 02:08 PM
xntrik's Avatar
He is worried about the yoke bottoming out in the transmission. Not falling out into the floor.
Old 12-25-2005, 02:16 PM
xntrik's Avatar
HTH,
Don
That only works IF they are supplying the entire shaft AND the front yoke... which they are....... yokes might vary as to depth on the trans shaft, that is, the distance from the tail shaft end to the u-joint centerline.
With an existing yoke, you push it in all the way and measure center of the front u-joint to the center of the rear U-joint, then subtract for the desired clearance.
Old 12-25-2005, 02:18 PM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
my driveshaft guy say's to bottom the yoke out then pull it out 1", measure center of yokes as a final measurment.
Old 12-25-2005, 02:41 PM
xntrik's Avatar
That is what I said in my last post, except I said ----- bottom it, measure, then subtract the desired clearance from your measurement.
1" clearance where/when ?? (it constantly changes during suspension travel).... at ride height or when the suspension is loaded for the driveshaft to be pushed into the transmission as far as it might??
The only reason the clearance is there is to prevent the yoke from bottoming out in the transmission, which is Bump's concern.
I have seen people measure at ride height and add that inch on a short yoke and when the suspension unloaded the yoke was so far out it twisted on the trans splines, cracked the yoke which angled off a few degrees and the front of the driveshaft flew out just like it had broken a front joint... Oh Oh..... some identical looking yokes have shorter splines inside. You want as much spline contact as possible for strength.
BUMPSTICK has a close clearance at ride height and needs to know if suspension travel will bottom it out into the transmission. Hence he has to load the truck down.
He might end up having to shorten the driveshaft 1/2 inch.....
FOOD>>> FOOD>>>
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Turbo 400 yoke question...?"
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
turbo 400 not working 49dream Transmission - Rearend 4 03-05-2005 07:18 PM
GM Turbo 400 trans front seal housing question Gary Shugart Introduce Yourself 1 01-13-2005 02:56 PM
a turbo question. Super Chevy Engine 16 01-24-2004 02:44 AM
7ooR4 vs 400 turbo? WBhunter Hotrodders' Lounge 4 04-25-2002 01:54 PM
